Generic round surface mounted or recessed light
5476 Downloads
4 Stars from 1 Votes
Minimalist generic round downlight/uplight/wall light
Why this lamp?
* mounts on all surfaces (ceilings, floors, walls, objects, etc.)
* optional lens and diffusor
* recess parametrizable (any distance from surface, incl. surface mounting)
* diameter and depth scalable in large ranges (depth down to 20 mm!)
* realistically rendering (metal reflector, dimmed diffusor when lamp off)* minimalist design
* all parameters thoroughly documented
* no junk parameters, well almost… :)
RevitCity Division: Electrical > Lighting > Recessed Cans
Uploaded By: matthiaswolffgr
Uploaded On: Sun, May 9, 2021
Original Creator: Matthias Wolff
Sat, May 15, 2021 at 9:38:26 AM
stevenpapke
Joined Sun, Dec 2, 2012
This family appears to be saved in Revit 21 and doesnt open in 20.  Do you have your original in 20 you can post?
stevenpapke
Thu, Jun 10, 2021 at 5:35:00 PM
Gisela180396
Joined Fri, Jun 22, 2018
Holaa como estas? Tengo RVT 2021 y no me deja agregarlo ni aun asi, tendras una versión inferior, por fa?? Gracias Smile
Wed, Jul 20, 2022 at 12:01:25 AM
JAVIMEX
Joined Wed, Mar 16, 2016
tengo 2021, y dice que esta en una posterior osea 2022 0 2023.. que raro este archivp fue subido en 2021. podrias subirlo nuevamente y seria util aclarar a version. saludos
Wed, Jul 20, 2022 at 12:03:44 AM
JAVIMEX
ya vi!!! si esta en 2022!!! en la vista previa de abri archivo en revit siempre indica version en efecto es 2022..
Fri, Oct 7, 2022 at 9:14:39 AM
vrazzano
Joined Thu, Dec 10, 2020
I have revit 2021 and it says it was created in a later version. Please upload the earliest year version you are able.
Mon, Mar 10, 2025 at 10:01:15 AM
Lossinat
Joined Mon, Mar 10, 2025
The background music of Geometry Vibes is awesome! It gives a dynamic and exciting feeling, which perfectly matches the rhythm of the game.
Tue, Apr 22, 2025 at 2:39:12 AM
jamieoliver
Joined Mon, Dec 19, 2022
Hi guys
Tue, Apr 22, 2025 at 2:41:08 AM
jamieoliver
I can’t believe how much fun I’m having just flinging myself at other sheep. Crazy Cattle 3D
Thu, Aug 7, 2025 at 6:57:48 AM
walterliz
Joined Thu, Aug 7, 2025
The design is not too complicated
Page generation time: 0.2186
