15 Users Online (14 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
8-Lt Minimal Traditional Pendant Chandelier
6398 Downloads
4 Stars from 1 Votes
Based from custom manufacturer Two Hills Studio's CB1C Chandelier at its maximum dimensions.
https://twohillsstudio.com/portfolio/chandelier-cb1c/
Face Based Model howver the Ref. Level is at the bottom of the fixture so the bottom of the fixture will be at the floor/ref level of your model. Heights are changed with the  instance paramters for the "bottom of fixture" and "the pendant drop."
The sub family does not have a photometric parameter for an .IES file
Product Version: Revit Structure 2020
Uploaded By: mdav1
Uploaded On: Thu, Sep 3, 2020
Original Creator: mdav1
Mon, Feb 5, 2024 at 3:52:29 AM
natalianahi
Joined Fri, Jun 27, 2014
Funciona sólo si se aplica en el piso, y luego se varía la altura en: boyyom of fixture. También se puede regular su propia altura.
It works only if it is applied to the floor, and then the height is varied in: boyyom of fixture. You can also adjust your own height.
Page generation time: 0.1696
