Laundry - Compact Stacked Washer/Dryer - Whirlpool
31554 Downloads
4 Stars from 9 Votes
Laundry stacked washer/dryer units based on the Whirlpool Compact models.  Materials are controlled by parameter settings.  Size is based on unit and not parameter controlled.
25-3/4" D, 24" W
Recommended side and rear clearances from manufacturer are included with reference planes for alignment.
CSI Division: 11 Equipment
RevitCity Division: Equipment > Residential > Washers & Dryers
Uploaded By: stohner26
Uploaded On: Mon, Aug 3, 2020
Mon, Aug 24, 2020 at 4:13:47 PM
tannerbateman
Joined Fri, May 1, 2020
3 Stars from 1 Votes
Does not work properly.
Mon, Aug 31, 2020 at 5:52:19 AM
jeremyrooz
Joined Wed, Feb 23, 2011
any chance you can save this in an earlier version?
Wed, Oct 21, 2020 at 1:53:25 PM
bakejame
Joined Tue, Mar 31, 2015
There is something wrong with your model. When I try to place it in my design the model gets placed with the bottom of the washer against the wall instead of against the floor. I really like the design you made, but it is useless unless I can figure out how to make it attach to the floor instead of the wall.
Sun, Nov 22, 2020 at 1:22:56 PM
c03koan
Joined Thu, Oct 6, 2016
I have the same issue I see elevation view in plan view
Mon, Dec 14, 2020 at 11:31:30 AM
Plattinum
Joined Sat, Apr 20, 2013
it works properly, you just need to use place on work plane instead of place on vertical face
Sun, Dec 26, 2021 at 11:05:34 AM
nvarch
Joined Sun, Dec 26, 2021
Can anybody help me? I pressed Download but nothing happens. Then I clicked Click here if not automatic download in 5 second but a lot of weird coding characters appear!
Mon, Jan 10, 2022 at 11:12:41 PM
gadwylie
Joined Wed, Mar 11, 2009
narch, were you logged in when you tried to download? also try with a different browser
Tue, Apr 25, 2023 at 9:35:31 AM
blackspoons36
Joined Fri, Aug 23, 2013
Worked perfectly! Just had to change "Place on Vertical Face" to "Place on Face" when placing in plan. Nice, simple, yet detailed enough design.
Thank you!
Page generation time: 0.5343
