ISCA-101-D-T
81 Downloads
ISCA-101-D-T
Watts ISCA-101-D-T Industry Standard back-to-back horizontal tapered thread water closet carrier with epoxy coated cast iron fitting, 4"(102) no hub waste and 2"(51) no hub vent connections, epoxy coated cast iron threaded faceplate assembly, epoxy coated cast iron foot supports with incremental measurements embossed onto legs to easily adjust height of carrier to most commonly used fixture requirements. Adjustable for standard and wheelchair height, threaded ABS nipple with integral test cap and neoprene bowl gasket, plated hardware and chrome cap nuts. Carrier complies with requirements of ASME A112.6.1M up to a 500 lb. (227 kg.) static load.
CSI Division: 22 Plumbing
RevitCity Division: Plumbing
Uploaded By: iandevera
Uploaded On: Wed, Jan 16, 2019
Page generation time: 0.0151
