2-Piece, Full Port, Brass Ball Valves - FBV-3C
1312 Downloads
Series FBV-3C & FBVS-3C 2-Piece, Full Port, Brass Ball Valves are used in commercial and industrial applications for a full range of liquids and gases. They feature a bottom-loaded blowout-proof stem, virgin PTFE seats, thrust washer, and adjustable stem packing gland, stem packing nut, chrome plated brass ball, brass adapter, and steel handle. Model FBV-3C has threaded end connections. Model FBV-3C-TH has tee handle with threaded and solder connections. Model FBVS-3C has solder end connections. Pressure Rating for 1/4 in. ‒ 2 in. (8 ‒ 50mm) is 600psi WOG and 150psi WSP. 2 1/2 in. to 4 in. (35 ‒ 100mm) is 400psi WOG and 125psi WSP.
CSI Division: 22 11 00 Facility Water Distribution
RevitCity Division: Plumbing > Distribution
Uploaded By: iandevera
Uploaded On: Mon, Dec 31, 2018
Thu, Feb 19, 2026 at 11:45:50 AM
kirakit
Joined Fri, Sep 12, 2025
After finishing a long lab report, I reread it and realized it sounded way more robotic than I intended. I had spent so much time fixing grammar that the tone just felt off. That’s when I tried an ai-humanizer https://detector.io/ai-humanizer to make the wording smoother without rewriting everything from scratch. It actually helped my draft feel more like something I would naturally say.
Page generation time: 0.0439
