15 Users Online (13 Members):
Reduced Pressure Detector Assemblies, Stainless Steel - 957RPDA Series
358 Downloads
Series 957RPDA, 957NRPDDA, 957ZRPDA Reduced Pressure Detector Assemblies prevent the reverse flow of fire protection system substances from being pumped or siphoned into the potable water supply. The 957RPDA incorporates a meter to detect ground leaks and unauthorized illegal taps, greatly reducing annual water expenses. It consists of a compact, stainless steel body with stainless steel internal parts, two check valves, a pressure-differential relief valve, shutoff valves, torsion spring checks and relief valve, and bronze, nickel-plated test cocks. Series 957RPDA, 957NRPDDA, 957ZRPDA is 70% lighter than traditional designs and is ideal for health hazard cross-connection, such as on fire sprinkler systems. Check with local water authorities for installation requirements. Maximum Working Pressure: 175psi (12.06 bar). |
CSI Division: 22 11 00 Facility Water Distribution RevitCity Division: Plumbing > Distribution
Product Version: Revit MEP 2014 |
Uploaded By: iandevera
Uploaded On: Mon, Dec 31, 2018 Original Creator: Allied Technical Solutions / Watts Water Technology
