Double Check Detector Assemblies, Stainless Steel - 774DCDA Series
611 Downloads
Series 774DCDA Double Check Detector Assemblies prevent the backflow of fire protection system substances from being pumped or siphoned into the potable water supply. They have a compact construction and short lay length, ideal for retrofit installations. They feature a lightweight stainless steel body, thermoplastic and stainless steel check valves, and low head loss. Series 774DCDA can be installed in the horizontal or vertical flow-up positions. It is designed for installation on applications identified by local authorities as non-health hazard, such as on fire protection systems. Maximum Working Pressure: 175psi (12.06 bar).
CSI Division: 22 11 00 Facility Water Distribution
RevitCity Division: Plumbing > Distribution
Uploaded By: iandevera
Uploaded On: Mon, Dec 31, 2018
Page generation time: 0.0355
