23 Users Online (21 Members):
Jaquar Under Counter Basin
1434 Downloads
Under counter Basin with Fixing Accessories Set Size: 555x425x195 mm, Shape : Oval
Vitreous china sanitary ware products are fragile in nature and need to be handled with care (to avoid personal injury) at all times during its storage, handling, installation and use thereafter. The product is heavy and it is recommended that two persons hold it while it is being fixed. Carefully inspect the new product for damage before installation. Risk of product damage. Over tightening may cause breakage or chipping of vitreous china. Risk of external leakage. Do not lift or rock the bowl after placement. Always test your cleaning solution on an inconspicuous area on the product before applying it to the entire surface. Do not allow cleaners to sit or soak on the product. Use a soft, dampened sponge or cloth to clean. Never use abrasive material like a bristle brush or scouring pad. Wipe surfaces clean and rinse completely with water immediately after applying cleaners. Clean Chrome, stainless steel surfaces once a week. Do not use cleaners containing chloride on chrome, stainless steel. If used, rinse the surface immediately to prevent corrosion. Wherever chrome plating is used on the products, use only warm water to clean and then dry with a soft cloth |
CSI Division: 22 Plumbing RevitCity Division: Plumbing
Product Version: Revit Architecture 2018 |
Uploaded By: cobipal
Uploaded On: Tue, Sep 25, 2018 Original Creator: Manish Paul Simon
