Watts Double Check Valve Assemblies - 757, 757N
390 Downloads
Series 757, 757N Double Check Valve Assemblies prevent the backflow of pollutants that are objectionable but not toxic, from entering into the potable water supply. Its compact housing consists of two independently operating tri-link check valves, two shutoff valves, and four test cocks. It features a stainless steel housing and sleeve and is 70% lighter than traditional designs. Series 757, 757N is designed for non-health hazard applications and may be installed under continuous pressure service to protect against both backpressure and backsiphonage. Maximum Working Pressure: 175psi (12.06 bar).
CSI Division: 22 Plumbing
RevitCity Division: Plumbing > Distribution
Uploaded By: iandevera
Uploaded On: Tue, Aug 7, 2018
Page generation time: 0.0268
