Double Timber Frame Door
22877 Downloads
5 Stars from 4 Votes
Door including options to have architraves, door handles (either knobs or levers) and also were these handles are to be located. ie: Only handles to the exterior and architraves to the exterior for a double cupboard door... Also includes the usual adjustable door swing and setback to whether the door is flush or recessed as well as being able to make the doors uneven if wanted.
RevitCity Division: Doors & Openings > Flush > Double
Uploaded By: Mr Spot
Uploaded On: Sat, May 29, 2004
Original Creator: Mr Spot
Sun, Oct 21, 2012 at 1:27:43 PM
adriandiciahall
adriandiciahall Avatar
Joined Sun, Jan 30, 2011
3.5 Stars from 3 Votes
Revit 2013 reports that it cant create that type when i try loading this into a project. Hence I cant use this door at all.
Sat, Nov 30, 2013 at 5:50:27 AM
IIvII
Joined Thu, Nov 28, 2013
did you load the family under doors
Wed, Sep 27, 2017 at 2:01:53 PM
Valerok04
Joined Wed, Sep 28, 2016
works great for me
Page generation time: 0.6784
