Fake Section marker
1602 Downloads
Fake Section marker
This is a modified fake section marker provided by www.Revitopia.com. As a 2 click operation, it utilizes line based detail component and embedded annotation objects. There are 3 primary parameters; Sheet(where you put the sheet number), Detail(where you put the detail number), and Head angle(to rotate the bubble). This was a solution to the use of AutoCAD Details being on a Revit project and to avoid creating “fake” detail views for placing on sheets.
CSI Division: 09 60 00 Flooring
RevitCity Division: Annotations > Heads > Section Heads
Uploaded By: jgkaltre
Uploaded On: Tue, May 17, 2016
Original Creator: SRobbins1977
Wed, May 18, 2016 at 1:20:45 PM
jgkaltre
Joined Wed, Mar 31, 2010
See Updated Version with additional parameters
jgkaltre
Page generation time: 0.0889
