Expansion Joint - Wall to Wall - 8" gap
1778 Downloads
5 Stars from 2 Votes
Insert as a DOOR!!
This is an expasion joint from wall to wall, mostly to be used with gypsum board walls.
The gap is 8". The plan represensation will show the joint gasket details. The elevation will show the trim and middle metal, as well as the 2 side expansion gadgets.
Both metal and expansion gadgets allow material selection.
This joint system is similar to InPro 233-A07 wall to wall expansion joint
CSI Division: 07 90 00 Joint Protection
RevitCity Division: Walls
Uploaded By: vaamarieta
Uploaded On: Tue, Apr 5, 2016
Original Creator: Marietta Haywood
Page generation time: 0.0753
