One Wooden Wall mounted shelf
11836 Downloads
Parametric. You can change the width and depth of the shelf, and its height off the ground. You can also change how far apart the two wall supports are.
REVIT 2016 (not 2015)
Note: the elevation constraint measures to the bottom of the support, not the shelf. Make sure the two elevation constraints are the same.
CSI Division: 12 30 00 Casework
Uploaded By: annieruth7
Uploaded On: Wed, Sep 23, 2015
Page generation time: 0.4179
