Nested SL winow with frame & SP file by Er. L.J.Upadhyay.
1250 Downloads
Nested SL window having 1 frames & 1 ML door panel choice. Wooden frame can be single or double rebate. If you do'nt need ventilator- simply set the vent Ht to zero.  Multi lite panel can be 1V x1H to 5V x 3H lites of glass or other solid material. There is a extra frame(2ndry frame)  arroun multi lites, who's width can be zero by simply set Stile panel offset and rail panel offset to zero, if you do'nt need it. Swing of Vent leaf as well as window leaves are operable by setting 3D swing angle. etc.  etc.  Lallan Ji
Most params are shared Params
CSI Division: 08 50 00 Windows
RevitCity Division: Windows
Uploaded By: Lallanji
Uploaded On: Tue, May 12, 2015
Original Creator: ContriverBIM by Lallan Ji
Wed, Nov 4, 2015 at 1:23:40 PM
Nikkiru
Joined Sun, May 10, 2015
5 Stars from 2 Votes
I love it! Thanks a lot and great job!
Page generation time: 0.0482
