Multi Mullion Window
3992 Downloads
5 Stars from 4 Votes
This window has the capability to have 0 to 10 mullions in the horizontal and vertical directions. Each mullion can be placed at random distances from the bottom or left side. VD# or HD# is to specify the Vertical or Horizontal distance of the numbered mullion. To Change the mullion count change the number under the constraint section of Edit Type.
The family is a little slow when making changes but seems to work fine once loaded.
Hope this helps,
smh
CSI Division: 08 51 00 Metal Windows
RevitCity Division: Windows > Miscellaneous
Uploaded By: ScubaMan
Uploaded On: Thu, Dec 4, 2014
Original Creator: smh
Mon, Apr 13, 2015 at 5:26:50 AM
dineal27
Joined Mon, Mar 16, 2015
good job
Sun, Mar 20, 2016 at 10:18:21 PM
dwestera
Joined Mon, May 18, 2015
Perfect, just was I was after!!
Thu, Dec 15, 2016 at 7:44:57 PM
ncyhdz
Joined Sat, Dec 21, 2013
Is there one like this but with archtop?
Sat, May 11, 2019 at 11:09:00 PM
yadjadie
Joined Thu, Sep 29, 2016
Excellent job, please instruct how to make mullions visible in elevations - thanks
Sat, May 11, 2019 at 11:22:18 PM
yadjadie
Page generation time: 0.1679
