11 Users Online (9 Members):
K-Series Bar Joist-Rod Web__w__Adjustable-Seat-Angles
9418 Downloads
This is a modified Revit K-Series Bar Joist that has parametric adjustable seat angles on each end. By default, the bar joist comes in as a standard bar joist with straight/flat seats; however, under the model properties for the bar joist, there are parameters to adjust the seat angles.
1) First, check the parameter called, "Show Angled Chord Legs at Seat".
2) Then adjust the Inner and Outer Heights of the Seat. There is a right side and a left side. |
CSI Division: 05 12 00 Structural Steel Framing RevitCity Division: Structural > Framing > Steel
Product Version: Revit Architecture 2014 |
Uploaded By: jroh
Uploaded On: Sun, Aug 24, 2014 Original Creator: JRoh Digital
Thu, Feb 11, 2016 at 9:19:39 AM
Joined Thu, Oct 18, 2012 No rating This user is offline |
Does anyone know why when you try to change the size of this family it says can not create type?
Fri, Sep 14, 2018 at 10:33:11 PM
Joined Tue, May 1, 2018 No rating This user is offline |
Really good Bar Joist man, saved the day.
