13 Users Online (11 Members):
2d Post Tension (PT) Cable
1572 Downloads
These is a 2d Post Tension Cable call out and symbols. Below is a list of the files that are used with it. Please let me know if you see something that would make these better.
PT - Post Tension.rfa is the main file. It's the one will use to place your cable. I have 4 Family Types setup in it. It can be easily changed up to do what ever you need.
PT - Force Tag.rfa is the tag that you need to call out the Force on that Cable. There are 2 types setup here. one for Kips Per FT and one for Total Kips.
PT - Text is used to show the height of the cable. PT-text are just symbols you can place them were ever you need them.
PT - Offset End. I made it up so if i need to work around an opening in the slab. It's still in Beta. It will get you around the opening but you are going to have to work for it. I'm hoping to think of a better way to do it later on.
You will also need to add two Parameters to your Shared Parameters. One called FORCE for Discipline Structural and Type of Parameter Force. The other is FORCE PER FOOT for Discipline Structural and Type of Parameter Linear Force. |
CSI Division: 03 30 00 Cast-In-Place Concrete RevitCity Division: Structural > Framing > Concrete
Product Version: Revit Structure 2013 |
Uploaded By: Cadman202
Uploaded On: Tue, Feb 5, 2013 Original Creator: cadmam202
Fri, May 17, 2013 at 1:23:51 PM
Joined Tue, Jan 10, 2006 No rating This user is offline |
I am only getting 1 file when I download this (2d_Post_Tension_PT_Cable_13723.rfa) its a dot with a text entry. I think this looks like a great component and would like to try it. Can you check to make sure its all on the revit city website. Hopefully I am not missing something in the download.
Thanks
Keith
Mon, Oct 14, 2013 at 5:28:35 PM
Joined Tue, Jul 23, 2013 No rating This user is offline |
Structural columns Trusses
Fri, May 16, 2025 at 7:47:11 AM
Joined Fri, May 16, 2025 No rating This user is offline |
This Revit download provides a well-modeled architectural component that can enhance any design project with added detail and realism. This is a blocky blast creation that fits perfectly with both conceptual and technical building layouts.
Mon, Nov 3, 2025 at 4:32:19 PM
Joined Mon, Nov 3, 2025 No rating This user is offline |
In the ever-evolving world of digital content, high-quality images are crucial for capturing attention and conveying messages effectively. AI Photo Editing is an innovative online platform that harnesses the power of artificial intelligence to help users effortlessly edit and enhance their photos, making the photo editing process faster and more accessible than ever.
