Sliding or Stacking Glazed Wall
25450 Downloads
4.5 Stars from 4 Votes
Stacking or Bi-folding partition wall with central pass door, modified model from someone on this site (Thanks!).
The only control to worry about is the 'Bi Fold' parameter - automatically flips central pass door depending on panel numbers (2 onwards), or stacks the panels to one side
RevitCity Division: Doors & Openings > Panel > Double
Uploaded By: matthewh75
Uploaded On: Wed, Jun 20, 2012
Original Creator: Matth75
Wed, Jun 20, 2012 at 6:51:31 PM
fabioloretti
Joined Thu, Jun 25, 2009
3 Stars from 2 Votes
Hi Matthew, thanks for the family. The only issue I found is that if I change the "Number Doors" parameter to an odd number the panel width changes to suit but the door still shows even number of panels.
This might be the bifold door I created and posted here! :-)
Wed, Jun 20, 2012 at 8:08:25 PM
vivististirijillo
Joined Wed, Jun 6, 2012
hello I need this furniture in revit 2011 if it is possible that someone may come up to revit city is the infinitely agradecere
Tue, Jan 22, 2013 at 7:22:28 PM
Megans
Joined Wed, Jun 10, 2009
Hi. I also need this saved back to 2011. Is someone able to do this? Really in need of a 4 panel that stacks to one side. Thankyou
Mon, Aug 25, 2014 at 5:26:35 AM
KaneNOS
Joined Fri, Nov 29, 2013
1 Stars from 2 Votes
These Doors are AWESOME! Thanks heaps
Fri, Aug 14, 2015 at 2:21:21 AM
racetsh
Joined Sun, May 20, 2012
Hi, This is the only model that I found which can be edited. Thank you so much. Nice work Smile
Fri, Aug 10, 2018 at 8:49:06 AM
samuelajay89
Joined Tue, Jul 17, 2018
Thanks Matthew, this is amazing.
Fri, Oct 12, 2018 at 5:46:50 PM
changlyn
Joined Wed, Apr 22, 2015
Great model! Can you tell me how to show the doors as open/stacked in a 3d view (as you have shown)?
Fri, Oct 12, 2018 at 5:56:05 PM
changlyn
Wed, Feb 27, 2019 at 12:26:34 PM
AbCh1124
Joined Wed, Apr 4, 2018
Hello, this is a great model! How do you get the door to show up open in 3D views?
Mon, Apr 22, 2019 at 8:32:43 AM
ARahim
Joined Wed, Apr 17, 2019
if i try to make it to 2 doors i get gaint door why ?
Sun, Sep 22, 2019 at 5:51:44 PM
Icey
Joined Thu, Aug 27, 2015
Hi, Great door, but it eould be brilliant if we could changewhich end it stacked to. Also as others have said - show it opened or closed in 3D views.
Cheers
Fri, Feb 21, 2020 at 11:35:52 PM
Joemodi
Joined Tue, Sep 12, 2017
Awesome work! could change the panel size , height width etc.. great work. thanks you
Fri, Aug 6, 2021 at 4:24:24 PM
#13
AthenaB
Joined Tue, Nov 8, 2016
How do I change the number of doors? I love the model but i need to reduce the number. clueless!
Thu, Oct 27, 2022 at 8:17:17 AM
#14
soenscad
Joined Thu, Mar 2, 2017
Thank you! Great model - very helpful!
Page generation time: 0.7567
