Upgraded door
7234 Downloads
4.5 Stars from 3 Votes
Upgraded door
New english version with report function.
This door is not a so simple one.
Free variable parameters:
Door width, Door height,
Sill on/off switch- blinds on/off switch,
blinds put up/down function with shading procent parameter,
built-in blinds on/off switch,
you can set the door opening angle (look the doorhandle),
you can modify the section number (case number),
you can set the opening section position,
the section number is able to set unlimitedly.
On the picture only one door element is seenable!
It was made by an building ingenieur not by an architect. My colleague told me to write this...
RevitCity Division: Doors & Openings > Specialty
Product Version: Revit MEP 2010
Uploaded By: formatpartc
Uploaded On: Fri, Feb 17, 2012
Original Creator: revittuning
Tue, May 8, 2012 at 3:41:29 AM
GoldWinter
Joined Mon, Nov 1, 2010
Excellent door! Looks great! Thanks so much!! Smile
Tue, Jun 5, 2012 at 6:09:28 AM
formatpartc
Joined Sat, Jan 22, 2011
4.5 Stars from 7 Votes
I will make a professional version of this door.The door element make for example the consignation and other useful things.
Thu, Mar 21, 2013 at 3:24:53 PM
chlamidascope420
Joined Mon, Mar 18, 2013
3.5 Stars from 3 Votes
Your English is superb, thank you for the verbose description.
Page generation time: 0.2687
