McKeon Coiling fire door
3078 Downloads
McKeon top coiling fire door with egress pocket door.  The egress door is located in a pocket in the wall and when the system activates, it swings into position and the coiling door drops from above.  This family includes all elements as well as a 'closed' and 'open' position.  It is hosted on a face of a wall, more specifically the back of the pocket where the egress door is in.  Ceiling height and width are instance controlled parameters allowing you to set them specifically for each import.  It includes 2d linework details (copies from McKeon) for both side tracks in plan view and then the coiling mechanism above the ceiling in elevation and section views.
CSI Division: 08 33 00 Coiling Doors & Grilles
RevitCity Division: Doors & Openings > Specialty > Rolling
Uploaded By: amalanow
Uploaded On: Fri, Jul 22, 2011
Original Creator: atm
Fri, Dec 20, 2013 at 3:15:34 PM
rezashahbazi
Joined Sun, Sep 29, 2013
tanks for revitcity
Page generation time: 0.1432
