Canopy
4978 Downloads
Canopy
Fully parametric canopy system based on the Mitchell Metals canopy system.  Allows you to drag it to the correct size and places the supports as required and recommended by the manufacturer.  The width/height is controlled to correspond to the manufacturer's maximum recommended dimensions.
The parameters are shared between the support and the canopy system, you will most likely need to create the shared parameters in your own project or use the attached file.
CSI Division: 10 73 00 Protective Covers
RevitCity Division: Site > Miscellaneous > Structures
Uploaded By: amalanow
Uploaded On: Wed, Mar 2, 2011
Original Creator: ATM
Page generation time: 0.1823
