Wood Fill (Hatch or filled region) drafting pattern
19387 Downloads
5 Stars from 11 Votes
This is an importable wood hatch drafting pattern. This means the scale of the pattern will change with the scale of the view.
CSI Division: 06 40 00 Architectural Woodwork
RevitCity Division: Fill Patterns
Uploaded By: malfonsi
Uploaded On: Tue, Jan 18, 2011
Original Creator: Mark Alfonsi
Tue, Aug 21, 2018 at 1:15:33 PM
S2000
Joined Thu, Nov 30, 2017
hi can you rotate this?
Mon, Aug 31, 2020 at 3:30:04 PM
jpbernier
Joined Fri, Dec 5, 2008
2.5 Stars from 3 Votes
Can this be rotated 45 degrees so that the pattern is vertical when applied to a wooden column, for example?  When I try to select a line in the pattern and rotate it, Revit thinks I am trying to roate the entire column.
Page generation time: 0.5245
